95 camaro 3.4 wont start
Old Mar 28, 2013 | 04:00 PM
  #21
Its been mentioned you need fuel and spark to make fire, but that's not all. You also need proper valvetrain to ignition timing. Did this no-start come out of the blue, meaning it ran fine when parked then didn't want to start the next time? Or, did something strange happen prior, and/or you changed something on the engine?
Old Mar 28, 2013 | 05:15 PM
  #22
Chaotic94's Avatar
September 2011 ROTM
9434v6:
Being that you own a 3.4, I'd hope you know by now that the 3.4 Camaros and Firebirds don't have MAF sensors. Just throwing that out there.
I didn't read through the whole thread here but it sounds like its flooding. Could be the fuel pressure regulator or possibly a bad vacuum line.
Old Mar 28, 2013 | 05:26 PM
  #23
9434V6's Avatar
Originally Posted by Chaotic94
9434v6:
Wait a sec. I never had to mess with one, but how does it not have a MAF? You have the air temp, idle control, and throttle position sensor. does it just delegate fuel depending on the tps then?? I couldve sworn I have seen a mod even for the MAF in a 207.
Old Mar 28, 2013 | 05:27 PM
  #24
Chaotic94's Avatar
September 2011 ROTM
Nope no MAF sensor. It has a MAP sensor on the intake.
Old Mar 28, 2013 | 05:33 PM
  #25
9434V6's Avatar
well, i missed a lesson on sensors somewhere. ive heard of map sensors, but never knew any details on them. or that the camaro had a map over a maf. well thats interesting. thanks for pointing that out. learn something new everyday. haha.
Old Mar 28, 2013 | 05:35 PM
  #26
Chaotic94's Avatar
September 2011 ROTM
I'm not sure that the map replaces the MAF but I know it had a map an not a MAF. Lol not sure why.
Old Mar 28, 2013 | 05:37 PM
  #27
9434V6's Avatar
that is odd. well i am still learning. i know a lot, but clearly not everything. i hadnt come across an issue with the intake system which is why I never knew. (ive taught myself what i know so far.)
Old Mar 28, 2013 | 05:59 PM
  #28
ok you have fuel, now need to check spark quality. weak yellow spark and/or low compression could cause a no fire. gona need to look at compression next. like 69 sayin if valves or pistons are not workin right she wont fire up
Originally Posted by Scott Blankenship
Question. Would the starter switch under the dash on the steering colum affect on how it starts. Just wondering
Old Mar 28, 2013 | 07:57 PM
  #29
uncle_bob62000's Avatar
Slick. Psi was about 40 and i checked the spark ole fashion way took wire off stuck a screw driver in the wire and seen spark
Just a caution to mention here for doing this on an ignition that has individual coil packs for each cylinder. I was told the "old fashioned" way may burn out a coil pack so I purchased a test light at Harbor Freight that clips on the plug and then the wire clips onto the tester. I think it was only about $5.00. It also makes it simpler testing spark on any car since it leaves both hands free.
Old Mar 29, 2013 | 01:49 PM
  #30
Scott Blankenship's Avatar
Ty guys ill check it out
