95 camaro 3.4 v6
Old Oct 18, 2011 | 11:08 PM
m-samuels@sbcglobal.net's Avatar
Default 95 camaro 3.4 v6
I'm try to find location of cam/crank sensor.If any one could help that be a blessing.Also what are signs of a bad one?Thx for your time on this matter
Old Oct 18, 2011 | 11:14 PM
3800camaro's Avatar
Crank position sensor should be located on the front of the engine right behind the crank pulley. Signs would be bad idle and major miss firing of it even starts and runs.
Old Nov 8, 2011 | 07:20 PM
TealCamaro95's Avatar
My 1995 Camaro V6 3.4 was working fine until someone who was attempting to fix my dashlights took my panel apart and went under the steering column. There were two orange wires that were cut but twisted together and he un twisted them and twisted them back together. After this the car would not crank. Very upset I attempted to check fuses and no fuses were blown the security light would stay on as I tried to crank it. I then called GM and they came to tow the car and repaired the wires that were stripped and replaced the ignition cylinder, still no crank. I do not understand what is going on with my car. It did this a time before but cranked the very next day. Also GM said that it would cost me $300 for a new security module that I may need to get it to crank. The problem is my bill is already $460. I need advice on what to do and what the problem could be if this is familiar to anyone.
Old Nov 8, 2011 | 09:20 PM
slick's camaro's Avatar
there is a sticky on how to bypass the vats system. use the search.
Old Nov 9, 2011 | 07:53 AM
iLL95's Avatar
I Like to Party
Super Member
^^^ this guy
