95 3.4 camaro wont idle when warmed up
95 3.4 camaro wont start has good fuel psi has good spark and i even tried to start it on either it wanted to start but wouldnt im at my wits end with this car had it on a computer and no codes at all. PLEASE HELP ANY IDEAS I NO ITS GOTTA BE A SENSER.
should be able to check with ohm meter. pretty sure 3.4 is the same as lt1 as far as temp sensor output. 4th Gen LT1 F-body Tech Articles if sensor is failing most times it shows -40 degrees which dumps max fuel to the cylinders.
