95 3.4 camaro automatic Running issue 911
![Unhappy](https://camaroforums.com/forum/images/icons/icon9.gif)
new plugs,wires,belt tention,icm,coil packs,fuel filter,Checked fuel pressure,oil change,cad not glowing at darkProblem=I live in Ohio so used to letting car warm up for 5-15.After that point get ready to take off and stalls BEFORE I SHIFT INTO DRIVE.restarts with strong but boggs alittle also.But it restarts with same issue.If i go to drive i dont feel confindent so park it.Seems like a fuel issue of some sort any IDEAS???Thanks PEOPLE
Just because the cat is not glowing does not mean it is not bad. I would guess cat here in this case. Get a infrared thermometer and get an actual measurement from both sides of the cat and see what it is. after your engine is warmed up to operating temp the cat should be within a few degrees inlet to outlet. More than say 10 degrees and I would be investing in a new cat for the car.
Massey
Massey
That is about as useful as testing tire pressure by pressing on the tire valve. lol
kuhlman187
12-10-2014 08:42 PM
