94 comaro 3.4 starts then dies?
Old Aug 14, 2008 | 05:38 AM
tanker425's Avatar
Default RE: 94 Camaro 3.4 starts then dies?
could it have sumthing to do with the lock cilinder because b4 i could take the key out while driving it does have a transponder key i have no stage 1 on the egnition but when i start cranking everything comes on fuel pump gages etc thanks 4 the advice
Old Aug 14, 2008 | 12:57 PM
02StanGT's Avatar
It is possible I suppose. Have you checked your battery connections for corrosion? Make sure all connections are snug w/ battery and starter.
Old Aug 16, 2008 | 01:14 PM
tanker425's Avatar
tried that it think im going to take it to chevy ill let u know how it turns out thnx
Old Sep 6, 2008 | 10:31 PM
tanker425's Avatar
i got it to start but i only had a gallon of gas so it died but now it wont even crank unless i jump the starter to the selonoid
Old Sep 6, 2008 | 10:35 PM
tanker425's Avatar
new batt starter selonoid n all connections to batt n starter r good headlights come on the security light does not flash it does nuthing is there a module for the egnition ? if so where would it be n can it be tested?
tlgrooms
Nov 11, 2014 02:47 PM
chip655
May 18, 2011 05:46 PM
datboypatrick954
Jun 21, 2009 04:19 PM
jonburgess
82-92 V6 Tech
May 16, 2008 03:29 PM
ducatiguy
Oct 15, 2005 12:36 AM
