93 v6 warm engine issue
93 v6 auto that runs fine while cold but as soon as it warms up it will miss and pop through the throttle body,when it cools down again its just fie,till it warms up,,scanned ecm and all i get is 36 (24 x)ive been trying to chase this code down with no luck,ive replaced every sensor on this car with new icm ,coils ,wires ,plugs,new cat converter,good compression all over,,checked fuel pressure all is good,,already checked all of wiring also,,any tips or ideas??
already installed cam sensor,as well as every other sensor on this car,,reset ecm and as soon as i crank still it comes up with code 36,,does anyone know what conditions this code will create,,reason i ask is that car runs good in open loop but soon as it switches to closed loop my problems arrive,,sluggish,intake backfire,but if i really step on it it will take off,,casual driving it is terrible
Well..i had a 95(Ish?) had it for a very short time corsica tha sounded exactly like that (minus the code..i never checked the code) and it turned out to be a simple little vacum line on the maf..or map sensor. You say when its floored it runs fine, does it actually die on you otherwise? Mine would actually just not run unless floored.
