93 Camaro v6 wont turn over, no dash lights
Ok guys first time Camaro owner here, its a 93 V6 and it stopped turning over one morning. When I put in the key and turn the gauges kinda flicker just a tad but nothing lights up, no turn over, headlights won't light up, horn doesn't work, but my interior light does work so its not the battery. I think it might be the ignition switch so I'm trying that out but does it maybe sound like a short somewhere? All fuses are good, I checked those.
Thanks! |
sounds like a dead battery or bad connection at the battery, take the cables off and wire brush the heck outa them
Originally Posted by Wiggy24
(Post 687670)
Thanks! |
Ok update: battery only had enough juice to power the ceiling light. Got it charging now. Any idea why it drained? Maybe bad wiring somewhere?
center consol light was on?
I'd check to see if you have any lights staying on or with the key off start proding fuses to see if theres current flowing. that'll show you where your drain is.
(Post 687747)
