A 93 3.4L's mpg?
Old Nov 22, 2007 | 02:42 PM
Red93Camaro's Avatar
Default A 93 3.4L's mpg?
What does a 93 3.4L v6 get for mileage? My tank hold 15.5 gallons...
So ...lets say I'm driving it normally Under 3k rpms all day What mpg should I get city and Highway?
I know it depends and theres alot of variables and stuff....But just a general idea would be nice.
ps...What can I do/ put in the car to make this more fuel efficiant? thanks!
Old Nov 22, 2007 | 03:07 PM
02StanGT's Avatar
Default RE: A 93 3.4L's mpg?
Thank Edmunds.com. I know using internet search engines can be difficult, but please SEARCH before asking questions.
Dimensions
Exterior
Length: 193.2 in.
Width: 74.1 in.
Height: 51.3 in.
Wheel Base: 101.1 in.
Curb Weight: 3241 lbs.
Interior
Front Head Room: 37.2 in.
Rear Head Room: 35.3 in.
Front Leg Room: 43 in.
Rear Leg Room: 26.8 in.
Luggage Capacity: 12.9 cu. ft.
Maximum Seating: 4
Performance Data
Performance
Base Number of Cylinders: 6
Base Engine Size: 3.4 liters
Base Engine Type: V6
Horsepower: 160 hp
Max Horsepower: 4600 rpm
Torque: 200 ft-lbs.
Max Torque: 3600 rpm
Drive Type: RWD
Fuel Data
Fuel
Fuel Tank Capacity: 15.5 gal.
EPA Mileage Estimates: (City/Highway)
Manual: 19 mpg / 28 mpg Automatic: : 19 mpg / 28 mpg
Range in Miles: (City/Highway)
Automatic: 294.5 mi. / 434 mi. Manual: 294.5 mi. / 434 mi.
Old Nov 22, 2007 | 03:46 PM
Thank you
Old Nov 23, 2007 | 12:38 AM
libertyforall1776's Avatar
Check/replace fuel filter, air filter, add fuel system cleaner for a couple tanks, use a throttle body cleaner spray. Switch to synthetic oil, and Dexron 6 Trans. fluid -- replace your Trans. filter if not done in many years/miles.
Apart from that add a CAI, Cat-delete or high-flow Cat, Headers and Cat-back, better air in/out of the engine is always good for gas mileage.
