5 speed transmission question
Old Aug 29, 2010 | 09:16 PM
1998camarossclone's Avatar
Default 5 speed transmission question
hey i got a 1998 camaro automatic 3.8 with a slipping automatic. found a 5 speed with clutch and bell, but its out of a 3.4...will it work?
Old Aug 30, 2010 | 02:04 PM
Massey's Avatar
There are alot of wiring differences, gearing differences, and the engine computer is not the same. The flywheel is not the same, nor is the clutch assy. The bell housing will bolt up to the engine and the tranny is the same as the 3.8L would have gotten. The starter will need to be changed as will the X member for the tranny. Driveline should be good. I would not personally do the swap. if your auto is just slipping a little try putting some posi additive in your tranny and see if it helps the slipping. It wont hurt you but it may help you. It helped my car when I first brought it home the tranny was chattering between 1st and 2nd. Hope this helps you
Massey
Old Aug 30, 2010 | 02:08 PM
I pretty sure the hydralic clutch system is completely different. I am not sure if the make up something that would work without getting a machine shop involved. The flywheel from a 3800 working with a clutch system from a 3.4?
Old Aug 30, 2010 | 02:20 PM
Massey's Avatar
Originally Posted by Gorn
I think the bell house is different from the 3.4 to the 3.8. 90 deg vs 60 deg. I pretty sure the hydralic clutch system is completely different.
The Series II 3800 uses the 60 deg. bellhousing pattern. Series I and 231 engines have the BOPC or 60 deg. housing pattern depending on if the engine is FWD or RWD. Series III engines also use the 60 deg. pattern
Massey
Old Aug 30, 2010 | 02:21 PM
Massey's Avatar
LOL @ Gorn, you were editing your post as I was replying to it.
Massey
Old Aug 30, 2010 | 04:24 PM
Yea I remembered they switched the bolt pattern. If you didn't use the quote I would have denied the whole thing.
Old Aug 30, 2010 | 04:27 PM
Massey's Avatar
LOL caught red handed!!
Massey
Old Aug 30, 2010 | 08:39 PM
the 3800 uses a 60 degree bell housing...
Nomad
Oct 4, 2011 11:13 PM
rext
67-69 V8 Tech
Sep 23, 2011 11:49 AM
96CamaroZ28
May 12, 2011 10:10 PM
Hippie23d
Aug 21, 2009 12:35 PM
Rroxon
Apr 12, 2009 12:44 AM
