3.8L injectors?
Old Dec 31, 2011 | 03:40 PM
305_camaro's Avatar
March 2012 Ride of the Month
Default 3.8L injectors?
I have heard of upgrading the stock 3.4L injectors to the 3.8L ones and gaining some power. Is this true or will it just overfuel the vehicle?
Old Dec 31, 2011 | 05:36 PM
I can not imagine changing just the injectors would effect much at all. Injectors can be limiting factors as you mod you motor. Say your injectors are only good till 220 HP, at that point injectors would help you. But let say you put the biggest injector in bosch makes. Your o2 sensor would just pick up on the added fuel and just cut back the pulse width to the injector until it sprayed the same amount of fuel your old injector sprayed.
Old Dec 31, 2011 | 11:36 PM
305_camaro's Avatar
thanks for clearing that up
lt1z2896
Mar 6, 2010 05:52 PM
Cris
Jan 24, 2010 03:48 PM
joeSScamaro
Sep 4, 2007 02:49 PM
8485Chevycowboy
Jul 11, 2007 03:45 PM
sepadowd
Jun 15, 2007 08:50 AM
