3.8 V6 INFO/MODIFICATION GUIDE
3.8L V6 INFO
L36 3800 Series II (3.8L/231ci)
OHV 90* V6 (Bore 3.8in/Stroke 3.4in)
Compression Ratio: 9.4:1
Firing Order: 1-6-5-4-3-2
Injector Size: 22lbs
Intake Manifold: 95-98 Angled, 99+ Straight
Throttle Body: 65mm Hitachi
Thermostat: 95-98 195*, 99+ 180*
Flywheel HP: 200 @ 5200 rpm
Flywheel TQ: 225 @ 4000 rpm
Gears: 3.08 Auto, 3.23 Standard, 3.42 Y87
3800 PERFORMANCE PACKAGE (Y87)
Limited Slip Differential (G80 Code: 96-98 Auburn, 99-01 Zexel-Torsen)
P235/55R16 Goodyear Eagle Tires
Dual Outlet Exhaust
Sport Steering (14.4:1 ratio, same as V8 Cars)
Four-wheel Disc Brakes (J65 Code)
RS PACKAGE
Although many cars say 'Camaro RS' on the title, this does not mean they have a true RS Package. The RS Package Consists of:
3-Piece Rear Spoiler (extension on the stock spoiler)
Full ground effects (front, side skirts and rear)
Alloy Rims
RS Exterior Badges
BOLT-ON MODIFICATIONS
Exhaust:
Headers
High flow headers replace the restrictive stock manifolds, adding power and improving sound.
Pacesetter Headers
Part #: PSM-70-1209 (painted)
PSM-72C1209 (ceramic)
Available: www.summittracing.com $234.39 Painted, $376.39 Ceramic
www.texas-speed.com $204.99 Painted, $319.99
Cat-Back
Cat-Back systems are basically the entire exhaust system after the catalytic converter. Mandrel bent pipes flow better than stock pipes, and a high flow muffler replaces the restrictive stock muffler. Thus improving performance and sound.
Flowmaster American Thunder Cat-Back
Part #: FLO-17358 (98-02)
FLO-17357 (95-97)
Available: www.summittracing.com $285.88-$304.99 + SH
Hooker Aero Chamber Cat-Back
Part #: 7-16811 (98-02)
Available: www.texas-speed.com $349.99
Edelbrock RPM Cat-Back
Part #: EDL-5658
Available: www.summittracing.com $283.95
Pacesetter TFX Kat-Back
Part #: PSM-86-
Available: www.summittracing.com $259.99
Magnaflow Performance Cat-Back
Part #: MPE-15693
Available: www.summittracing.com $427.95
Borla Cat-Back
Part #: BOR-14813
Available: www.summittracing.com $885.99
Mufflers
High flow mufflers replace the stock restrictive muffler, thus increasing flow and improving performance and sound.
Hooker Aero Chamber Muffler
Part #: 7-21721
Available: www.texas-speed.com $89.99
Flowmaster 80 Series Muffler
Part #: 42583
Available: www.racerpartswholesale.com $101.61
Magnaflow Performance Muffler
Part #: MPE-14277
Available: [URL=http://www.summittracing.com]www.summittr
Dual Outlet Exhaust
RS PACKAGE
Alloy Rims
RS Exterior Badges
Exhaust:
Headers
Pacesetter Headers
Cat-Back
FLO-17357 (95-97)
Part #: EDL-5658
Part #: PSM-86-
Part #: MPE-15693
Borla Cat-Back
Part #: BOR-14813
Mufflers
Part #: 7-21721
Part #: 42583
Part #: MPE-14277
