3.8 Cold air Intake
My project is finishing up and I need a Cold air intake for my 96 3800. Any reason I should not get this one? Any others I should look at?
http://cgi.ebay.com/ebaymotors/95-96...=p4506.c0.m245
Personally I would avoid this, because:
1) It's almost certainly made in China, and I like to put American parts in my American car;
2) The filter is almost certainly garbage so you will need a new filter;
3) its held in place with zip-ties, and
4) I personally bought one of these generic intakes for a 1989 CRX and it didn't even come close to fitting - in fact, it was so bad that I couldn't use it at all. The pipe was bent about 1" in the wrong spot.
After shipping and a K&N filter you're looking at around $100, at least - just save up for a name brand and be done with it
^^ No, this won't work on a 2000 because the throttle body on a 95-97 is angled and its straight on 98+ cars. Maybe it would fit with a different elbow?
Last edited by Masospaghetti; Aug 10, 2009 at 03:12 PM. Reason: {edit} commented on above
I believe they make a similar one for your year. Although I've heard the 98+ intakes for quite a bit better than the 93' - 97' V6 factory intakes.
