3.73
Thinking about getting 3.73's. Just wanted to see if I could install them myself or if I would need to have a shop do it. If a shop did it how much of a bill would I be looking at if there were no problems?
This type of work is very area dependent. A guess would be between $300-$600 Labor. You want to make sure you find a show that does it all the time. These days there is no where near as many as there use to be. You should replace the pinion and the carrier bearings a the same time.
Setting up a rear is not complicated but it is unforgiving. You don't set it up right its a do over and you could roach the diff while you are at it.
3.73 in a V6 that's likely a daily driver? I dunno, for perspective, the (manual) ZL1 has 3.73 gears (3.23 auto):
http://www.camaro5.com/goods/camaro_zl1_brochure.pdf
