3.4L Part Name
Old Apr 15, 2008 | 08:56 PM
TomS68's Avatar
Default 3.4L Part Name
I need to replace a part as it's cracked and leaking some vacuum but it's not listed in my Haynes manual.
It is the rubber piece that plugs right into the top of the intake plenum. It branches off to two hoses of differing diameter from there.
It's location is right at the very front of the intakeplenum on the top. It isright in front of the test port on the fuel rail. If I remove the pieceall together the RPM races and I hear the sucking of the vacuum of the intake. What is this piece called?
Thanks,
Tom
Old Apr 15, 2008 | 09:07 PM
ridinsolo2's Avatar
Default RE: 3.4L Part Name
i am not sure what it is called but i had to replace mine and i just took it off and took it with me to a local autozone and they just got the part for me, i think it was like 5 bux or alittle less brand new
Old Apr 16, 2008 | 10:01 PM
02StanGT's Avatar
Where do the other hoses go? I want to say you're talking about the PCV valve/hoses, but not sure.
Ecidemon
Sep 3, 2012 04:16 AM
BlueKitsune
Nov 20, 2008 03:44 PM
IROCNeeveeZ28
82-92 V8 Tech
Jan 20, 2008 01:10 PM
evansrs
82-92 V6 Tech
Oct 10, 2007 08:53 PM
