3.4l missfire?
Ideally you should use a OBDI scanner, but you can also flash the codes. You can search the forum for the procedure to flash the codes.
problem 1. don't kno I have the same plug tuck away. its affecting anything I kno of..
problem 2. that is your coolant temp sensors on the head behind the coil packs. replace it.
problem 3. that's your fuel return line...
problem 4. your fuel return line in problem 3 goes there. purge.
problem 5. yes you can. but you can get from a link yard for $1.00.
did I miss anything...
