3.4 SFI V6 Specs 93-96 Camaro from GM DOCUMENTATION
Old Aug 22, 2006 | 05:30 PM
94CamaroSFI's Avatar
Default 3.4 SFI V6 Specs 93-96 Camaro from GM DOCUMENTATION
93-96 V6 Camaro Spec Sheet
Driver And Passenger Air Bags (93 Camaro was Chevrolet's first car with Passenger Air Bags) Four Wheel ABS, PASS-Key II Anti Theft System. ScotchGard Fabric Protector on seats and Door panels,Composite Body Panels Dent resistant and rust proof to keep this vehicle looking showroom new for many years (body wise)
L32 3.4 Liter V6 (207 Cu Inch)
60 Degree front Longitudinal, OHV
Bore:92.029 mm
Stroke 84 mm
Cast Iron block
Firing order 1-2-3-4-5-6
L (Front to Back ) 2-4-6
R 1-3-5
Horsepower:160
200 ft/lbs of torque
Knock Sensor Located Right Side Center of Block
Compression Ratio 9.0:1
Fuel: 87 octane
Fuel Tank Capacity= 15.5 Gallons
Total Engine Mass : 452 Lbs (Auto) 492.8 Lbs (Manual)
Sequential Fuel Injection
Computer Controlled Air/Fuel Ratio
Electronic Pulse (injection)
Cast Iron Block (29 Lbs)
Aluminum Intake Manifolds
Normal Oil Pressure:50-65 psi
Transmissions
Manual (M49)
Gear Ratios:
1st 3.75
2nd 2.19
3rd 1.41
4th 1.00
5th 0.72
Reverse 3.53
Use DexronII lubricant (2.8 L capacity)
Automatic aka Hydra-Matic 4L60E
4 speed Auto w/ Overdrive(4th gear Overdrive, Lock Up Torque converter Clutch)
1st 3.06
2nd 1.63
3rd 1.0
4th 0.70
Reverse 2.29
MAXIMUM Upshift speed: 1st-2nd=37 mph, 2-3=70 mph, 3-4th= N/A Above 56% throttle, Will not Make WOT 3-4th
MAXIMUM Upshift Engine RPM: 5200
Axle Ratio (Both Manual and Auto) 3.23
No. of Teeth- Pinion= 13 Ring Gear=42
COOLING SYSTEM
Thermostat Opens Coolant at 195 degrees F.
Single Fan ECM Controlled, RPM at Idle 1800-2000
Fan Switch point = 226 degrees F
Exhaust System
2.5" Single Exhaust All Stainless Steel
Single Catalytic Converter located underneath passenger seat
EXTERIOR DIMENSIONS
(In inches)
WHEELBASE=101.1
LENGTH(overall)=193.2
WIDTH=74.1
HEIGHT= COUPE 51.3, CONVERTIBLE=52.0
FRONT BUMPER TO GROUND CLEARANCE=5.1"
REAR BUMPER TO GROUND CLEARANCE= 13.7"
FRONT SUSPENSION
Independent W/ Coil Springs,SLA (Short/Long Arm W/ Coil Over Shock, Gas Charged Shocks.
REAR SUSPENSION
Salisbury Axle W/ Torque Arm,Trailing Arm,Track Bar, Coil Springs
Wheels And Tires
P215/60R-16 (STANDARD ON SPORT COUPE)
P235/55R16(STANDARD ON Z28; OPTIONAL FOR SPORT COUPE)
Rim Size
Cast Aluminum
16x7.5
16x8 (OPTION FOR SC, Z28 rims)
STRUCTURE
Full Unitized Steel Construction. Cowl,Roof,Underbody,And Body Panels Welded To Form Body Shell. Doors,Roof,And Hatch Lid Double Panel Construction
Total Glass Exposed Surface: 4,846.745 square inches. Convertible= 3,039.895 Sq In.
Lo-Beam Type:H4351
High Beam Type:H4352
Peace, and Godspeed
Aaron
94CamaroSFI
Old Aug 22, 2006 | 11:15 PM
JaySan's Avatar
Default RE: 3.4 SFI V6 Specs 93-96 Camaro from GM DOCUMENTATION
Do u no the specs. for a 98+ camaro's?
Old Nov 8, 2010 | 10:31 PM
QuadMan91's Avatar
How much horsepower ad torque does a stock 1994 3.4 SFI camaro get to the wheels?
Old Nov 8, 2010 | 10:45 PM
BasicConcepts's Avatar
Technical User
a 94 now like 130 maybe age reduces HP
Old Nov 8, 2010 | 10:46 PM
WIspartan1026's Avatar
May 2013 ROTM
stock crank hp: 160
wheel ~140ish.
santa6
Oct 22, 2014 10:20 AM
RaiderGT
Nov 6, 2012 06:16 PM
Calwooz
Mar 18, 2012 10:03 PM
Petepd
Jan 18, 2012 07:14 PM
