1996 Camaro 3.8 Oil Pan Replacement
Old Feb 2, 2012 | 04:55 PM
RFxCamaro's Avatar
Default 1996 Camaro 3.8 Oil Pan Replacement
So i did my research and i did everything as followed but still lack enough room to remove the oil pan. I removed the exhaust, starter, ac compressor so that i could get to the motor mount bolt, and tranny plate. Nothing else is in the way. I still need about 2" to remove the oil pan. It seems like something inside the oil pan is blocking it so i cant turn it sideways so thats not an option. I'm out of ideas of what i can do besides removing the entire motor. Any pointers or tips? The motor cant get any higher before you ask. It is already touching the cowl and yes i did remove the coil pack.
warbird281
Nov 4, 2009 03:38 PM
jxdesign
Apr 14, 2009 08:33 AM
dirtrackracer2b
Nov 2, 2008 03:24 PM
soulonfire11
Jan 14, 2007 02:13 PM
