1995 3.4L Thermostat replacement
Old Dec 15, 2006 | 12:15 AM
Camaron32's Avatar
Default 1995 3.4L Thermostat replacement
Has anyone replaced the thermostat, and if you had how did you get the bolts out?
Old Dec 15, 2006 | 06:52 PM
Default RE: 1995 3.4L Thermostat replacement
Use a 6 point socket, if the bolts are frozen and break, you will be SOL, as now you will have to drill them out.
Old Jan 5, 2009 | 09:27 PM
Camaron32's Avatar
I am able to locate the two bolts that hold the theromostat housing to the intake. Where I am unsure is that one of the bolts is under the air flow meter/intake manifold and I'm not sure how to get to that bolt. There is quite a bit of stuff in the way and I want to be sure before I go messing with it.
Old Jan 6, 2009 | 05:49 PM
libertyforall1776's Avatar
Been there, changed that it's easy, use a universal joint and if the tools you have don't fit well, buy ones that do... Pick up a Chilton or Haynes manual for your car as well.
gagger84
May 24, 2014 06:47 PM
Ted Von Kampen
May 10, 2014 11:50 PM
Ted Von Kampen
Mar 11, 2014 07:30 PM
thetal1
Oct 19, 2009 11:21 PM
silverscat
Sep 14, 2009 03:14 PM
