1993 Camaro RS 3.4SFI starting problem
When you say you changed the "plenum gasket" (air intake), are you talking about the rubber intake tube at the throttle body; the one that leads from air cleaner box to t.b.? Or the gasket between the throttle body and intake plenum? What else, if anything, did you mess with?
here is some info. why didnt you do the lower intake, thats the one that usually fails. white smoke could also be unburnt fuel.
https://camaroforums.com/forum/93-02...99/#post665301
https://camaroforums.com/forum/93-02...18/#post618955
