1/4 mile speed and time guess`s
i just rebuilt my 94 3.4 block cooked built ground up and once it gets nice here in central PA ill be taking it to the local strip but i was just looking to see what people are thinking it will do there here is what im running
30 over K.B. pistons/rings comp cams k kit
Port and polished Heads pacesetter headers MSD ignition box/ interfaces/coil packs 19lbs injectors adj fuel pre. reg K&N short ram induction all new bearings for tires i got a set of yokohama avs e1000 245/50zr with few miles on them i haven't re-geared it at all only a mini spool in the diff if you got any ideas id like to know |
Did you have the computer tuned in some way?
Know anybody with an newer ipod or Iphone? They have pocket dynos apps. My guess would be low to mid 15s. |
I'd say high 14's at 80mph
My guess is you will be keeping up with the 3.8L engines now at around mid to low 15s
Massey |
BTW what is a 1.6:1 Push rod?
Originally Posted by Gorn
(Post 518924)
In stock form, his was a 16.6 sec. 1/4 mile car, and the Z28 was 14.2 sec. I'm thinking he's somewhere between the mid to upper 15's. |
(Post 518868)
Know anybody with an newer ipod or Iphone? They have pocket dynos apps. My guess would be low to mid 15s. yeah i do but what about the connection from the ipod to car |
the push rods are 1.6:1 they are comp cams josh from ftpp set me up with them
I only ran a 16.3 @83 mph with my car. I also have 3.42's and he probably has 2.73s. Given my trans is stock and not rebuilt with 207k I could do better. I would say he would run low 16s.
Also they are 1.6 roller rockers, not push rods. |
ok do u know what they were stock because matched up to the stock ones they are longer thats whats got me wondering now
