Rose350 |
01-22-2011 11:35 AM |
1- you can probably instal the engine yourself if it's a turnkey. 2- you don't necessarily need a new transmission, when the guy says you need a new one he means that the way it is now it cant handle the power. with some parts like a clutch, gears, pressure plate and flywheel you can basically get a new trans for allittle over a grand. i'm in the same boat and im thinking of using specgear as a supplier. but before you do this definately ask around some tuning shops to make sure this will work for you
