Trans Woes
Old Oct 12, 2017 | 03:08 PM
simplez's Avatar
Default Trans Woes
I have a '95 Z28 automatic and suddenly the trans has taken a dump. I'm looking into replacing it but am not sure what exactly will work as far as years that will interchange and such. I have noticed that some are 2 piece (as in the bell housing can be removed from the trans) and some are all 1 piece.
I just want to make sure what I order is going to fit so any help on this matter is greatly appreciated.
Old Oct 12, 2017 | 06:07 PM
Everett#2390's Avatar
Check RockAuto
Old Oct 12, 2017 | 06:37 PM
I remember a thread that listed the variation. If you are looking for direct replacement I think you need a 95. Something is different in the electronic every year 94-95-96. I think that thread also listed what you had to do to switch between 94 and 95, maybe an internal wiring harness and a few other parts. I believe 96 was a lot more work. 93 is not a 4L60e so its not an option.
Old Oct 14, 2017 | 08:26 PM
MKCoconuts's Avatar
95 and newer are all PWM transmissions and they should all work. I have not seen a 4L60/E with a removable bell housing. You will need to swap your tail housing. Too bad you weren't in PA. I have a '95 4L60E sitting in my car port that I have zero use for.
750chop
Oct 8, 2009 08:24 PM
adirtypoostick
82-92 V8 Tech
Dec 6, 2008 08:33 PM
irax
Sep 15, 2008 06:38 AM
carlsbadlt1
Nov 4, 2005 09:59 AM
