Tailshaft not in line with driveshaft???
Old Jun 15, 2017 | 03:21 AM
DesertCamaro's Avatar
Default Tailshaft not in line with driveshaft???
Pulled motor and trans (3.8/T5) out the bottom. New motor and motor mounts. New clutch, flywheel. Lowered the body down over the engine bolted K frame to main frame. Then went to connect trans mount and crossmember....Tailshaft is almost 3 inch off center (towards passenger side) I have NEVER seen this before. Help Please!
Old Jun 15, 2017 | 04:39 AM
did you losen the bolts for the k member and see if it will move over.
Old Jun 15, 2017 | 06:34 AM
I will give that a shot first thing in the morning, Ill let you know!
Old Jun 15, 2017 | 09:49 AM
Pry bar for the win,,, That is why they make alignment tools
Old Jun 15, 2017 | 11:54 AM
Loosened the K frame bolts, got the trans centered. Bone head mistake! Thanks bud!
rs657f
Sep 11, 2014 05:50 AM
manslaughter299
Jul 24, 2012 03:17 AM
maudyZ28
LS Series Tech
Sep 15, 2010 03:06 AM
microkid
Nov 4, 2007 06:44 PM
