shift kit
Old Nov 13, 2007 | 08:25 AM
mycarsux88's Avatar
Default shift kit
i put a b&m shift improver kit in my 95 z28 but i lost 3rd and 4th everything looks fine but i found a 1in by 1/4 in metal cylinder that i have no idea where it goes help
Old Nov 13, 2007 | 10:11 AM
t9ojetpilot's Avatar
Default RE: shift kit
[8D] was this something that came with the kit?? or maybe fell out of the valve body when installing the kit?? if the kit says to remove it or be careful this may fall out you may have a clue as to where it goes from the kit instructions. if not i think my factory manuals show trans schematics and maybe i can help if i know what exactly it looks like, sounds like a spool valve kurt
Old Nov 13, 2007 | 10:37 AM
I'm curious where you found the part too. It sounds like one of the valves from out of the valve body.
Does your mystery cylinder have a couple of channels with cross-holes in it? It could be your 4-3 throttle valve?
apetsel
Mar 25, 2011 06:27 PM
bigtim1985
Sep 29, 2010 11:28 PM
th3po1son
Jan 20, 2008 08:56 PM
KoRN_Munky
LS Series Tech
Mar 25, 2007 02:49 AM
94Z28SHAKER
Jul 11, 2005 02:38 AM
