S**t....i blew up reverse
Well....this sucks.
I'll start off by saying I was pissed before this happened...and even more so after it happened. So i was stopped.....put the car in reverse (mind you i'm pissed at this point in the story) floored the gas and dumped the clutch and i moved about 3 feet back. In my angered state I was hoping that ugly noise I just heard was only the shifter slipping out of gear. Not so much :icon_eek: i had just blew reverse to high heaven! I had to drive about 2 min to get home from where i was at the time, 1st through 5th all worked just fine, but i tested reverse just to make sure once i got home and yep...it wasnt there anymore. How much (ball park) is it going to run me to fix, and what else might have gotted effed up when reverse went to pieces? Its a 94 v6 with a 5 speed (obviously) |
well, as you found out, inanimate objects don't care about your moods, but your wallet does.
Will it go into reverse with the engine off? it could be a whole host of things and I'd be speculating without more details |
yes, it oges into reverse with the engine off.
Originally Posted by v64thgen
(Post 617480)
What happens if you pump the clutch a few times while in neutral with engine running and then try reverse? |
Originally Posted by torque_is_good
(Post 617486)
what happens if, with the engine running, you go into neutral, release clutch for a few seconds and then, depress clutch and attempt to go into reverse?
What happens if you pump the clutch a few times while in neutral with engine running and then try reverse? First question-----goes right into reverse, it does get a little stuck when shifting back out. Second question-----havent tried that. |
....And, what happens if you put it in reverse with the engine off, start the engine with the clutch in, then try to go?
(Post 617490)
Blew the reserve on my ford truck once. I took to the dealership and they told me i burnt out some sensor in the tranny. Good thing it was under warranty. And yes I was pissed off when I blew it. Lol
(Post 617490)
another good test and me thinks you and I are heading down the same path dang, there i go with that thinking thing again |
(Post 617517)
yep
