Rebuilt trans help!!
I'm looking to replace the transmission in my 01 camaro. I came across what seems to me like one of those it's to good to be true sorta deals...I think..has anyone delt with these guys? Does it seem legit ? Any other suggestions?
Thanks
Camaro 1998 - 2002 4l60e Rebuilt Transmission 3.4, 3.8, 5.7 liter engines
Thanks
do you have a sixer or V8? If a sixer then as long as they send you the correct tranny it's a fair price. Warranties are nice to have but it's a pain to have to take out the tranny twice instead of only once. Are you ding the work yourself of removing it? If so, check craigslist for local shops who will do bench rebuilds. It's always better to look a person in the eye vs online sales
If you aren't doing the work yourself, and want to purchase the part yourself, don't expect warranty on the labor if the part should fail.
If you expect a shop to warrant their work then you must allow them to source parts themselves
if you already have a tranny get it rebuilt
drop the tranny and drive it over and have it rebuilt. You will be able to look the guy in the eye and look around his shop
also, while the tranny is out slap in a new rear main seal in the engine
i have a 95 z28 and when i got the car it wouldnt shift into 2nd gear. i have to bring the rpm up to 3000 and let the throttle go for it to shift to 3rd i thought maybe i was having an oil pressure issue so i dropped the pan and unbolted the valve body took it down and replaced the gaskets seperator plate. took spool valves out of valve body and cleaned the valves out with brake clean put the valve body back together and bolted everything back in put new filter an gasket put new fluid in and the trans is still doing the same thing. i have a few ideas whats wrong with it but it would be nice to hear some feed back on other peoples suggestions
