rear end help
Old Mar 27, 2014 | 09:34 AM
v64thgen's Avatar
Default rear end help
is there a thread on here that lists exactly what i would need to switch from my rear end (3.4 v6 manual with standard open diff, and drums) to a rear with disc brakes?
i know as far as bolting up they are an exact fit, im talking about if the other rear is 4 channel instead of my 3 channel what i need to do to make that work (or can i?), for the disc brakes does the master cylinder, or proportion valve (the mechanic mentioned that i think) need to be changed, im sure all the lines will be fine but is there a different fitting on the disc brakes as compared to the drums?
thanks
Old Mar 27, 2014 | 12:30 PM
Cheeks's Avatar
August 2011 ROTM
you need the backing plates, lines, rotors, calipers, pads
other then that, it shouldn't matter if the rear is 3 or 4 channel
Old Mar 27, 2014 | 01:02 PM
v64thgen's Avatar
do i need the lines because the connection to the brakes is different between drums and discs? or is there some other reason?
Old Mar 27, 2014 | 05:16 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I bolted in a 4 channel rear from an ls1 into my car with no major modifications, the brake lines were different though but I made it work.
Old Apr 4, 2014 | 09:24 AM
libertyforall1776's Avatar
Don't change out the rear end just to get disc brakes, just upgrade the brakes! You do have to open the pumpkin & release the axle shafts as I recall. Did the upgrade on my old '95 3.4L.
If you decide you want an LSD, all you need to do is swap carriers, why waste a rear end?!
Saaampson74
Oct 20, 2008 04:56 PM
libertyforall1776
Nov 10, 2007 03:04 PM
