posi
will this fit in a 98 camaro v6 GM 7 5 7 5 8 Posi 10 Bolt 28 Spline Gov Lok Eaton 3 42 Gears 4x4 s 10 Drag LSD | eBay
Yuppers.
will i have to change anything to make it fit
Shouldn't have too. Iirc, for the last 20 or years, the internals of a GM 7.5 " 10 bolt are the same.
Are you going to be doing this yourself? Rear gears isn't just a drop in and go thing. You do have to make sure everything is going "mesh" properly before it actually gets put to use. I'll see if I can find a vid for you. Edit: Here you go: |
