95z28 automatic
Old Dec 3, 2011 | 06:57 PM
Edwardgp's Avatar
Default 95z28 automatic
This car is great but my boy brought it home and it is stuck in forward. It is not the linkage or the shifter.
Old Dec 3, 2011 | 08:39 PM
Edwardgp's Avatar
The trans is stuck in forward but I do not know which gear. It is not the shifter or shifter cable that much I know anybody with any suggestions
Old Dec 3, 2011 | 08:41 PM
BasicConcepts's Avatar
Technical User
when you shift the car does the linkage at the trans move???
Old Dec 3, 2011 | 08:51 PM
iLL95's Avatar
I Like to Party
Super Member
Like BC stated, when shifting does the linkage cable move from the linking bracket to the tranny?
Old Dec 3, 2011 | 08:54 PM
Technical User
Originally Posted by iLL95
Like BS stated, when shifting does the linkage cable move from the link bracket to the tranny?
BS... im no BS lol
Old Dec 3, 2011 | 08:55 PM
iLL95's Avatar
I Like to Party
Super Member
Woops, corrected, my bad bro! haha
Old Dec 3, 2011 | 10:55 PM
so if you unhook the cable at the trans, the shifter arm on the trans will not shift? um before you go under a car and take it out of park make sure the tires are blocked really good so it wont move.
Old Dec 3, 2011 | 10:59 PM
If the linkage arm on the trans won't budge, something with the valve body is likely to be messed up/broken/disconnected/jammed. Did I miss any /'s?
Old Dec 4, 2011 | 07:52 AM
Edwardgp's Avatar
Yes we jacked it off the ground and the shifter and cable move freely
Old Dec 4, 2011 | 07:56 AM
Edwardgp's Avatar
The shifter,cable and trans linkage all move like they are suppose to
