94 Camaro z28 clutch problems
I was driving and shifting out of 2nd gear to 3rd gear and the car started vibrating and was loud Like if I through a couple rods and didn't want to shift into 3rd. It didn't want to shift into any gear while the car was running. so I shut the car and it smelled weird. I shifted through all the gears to make sure they engaged. so I started the car and noticed it didn't vibrate any more. So I tried to put it in gear and it didn't want go go into any gear again. the clutch felt normal when I was pressing it. So I had to get it home so I started the car in 1st and went through the gears with out being able to use the clutch. I checked the fluid and it was good.
