3800 series v6 to LT-1 swap
Old Aug 27, 2011 | 11:27 AM
Razor2's Avatar
Default 3800 series v6 to LT-1 swap
im currently in the middle of doing a v6 to v8 swap on my 96 camaro. I got the lt1 out of a 97 SS and im almost done with it. I was wondering if the t5 from the v6 will bolt up and if not will the bellhousing come off so i can put another on to make it work ? I know if the t5 bolts up it will not last long but i need something for right now, running short on funds.
Old Aug 29, 2011 | 10:22 PM
You can try a 305 Bell housing of a 3rd gen Camaro but your going to spend a lot of money getting a clutch that would hold up to the torque. The V6 clutch will not work with the V8 Fly wheel. The Bell housing must be from a Camaro. The truck 4.3 will bolt up but it will cause you shifter issues.
How can you be almost done if you don't have a tranny for it yet?
Just a friendly heads up. You did get the radiator from the Z? They are reverse flow you cannot make the V6 work without it being a huge pain. The v6 rad is not big enough anyways. If you are using the 97 computer there are a lot of changes in the wiring 96 to 97. You best bet would be to find a manual trans 96 Z PCM and harness this will avoid a wiring nightmare. You’re going to need a 96 LT1 instrument cluster also. The V6 cluster will be off on everything. The 97 cluster is a different design. If you already have the 97 PCM it can reflashed to 96 specs.
It would be great if you could share more about the project. A build thread in the project area would be great!
Good luck
Old Aug 30, 2011 | 08:04 AM
Razor2's Avatar
i almost done as far as the engine goes. ok would it be hard to install a 350 turbo or a 4l60e tranny ?
Old Aug 30, 2011 | 08:07 AM
Razor2's Avatar
wiring was a real head ache but i finally have it solved i think. yes ill post up some pics and give more info about the swap when im finshed with it. thanks for your help
Old Aug 30, 2011 | 08:49 AM
What computer system do you have? The 4L60e is controlled by a computer so you need the PCM and harness from an automatic car. The Th350 will need to be fitted with a speed sensor that will work with your PCM. The easiest way to do this swap is with a donor car. You may be able to find a wrecked, damaged motor, car for less then buying all these pc parts. Remember the PCM connect to all the sub systems crossing years can be a huge pain for someone who cannot trouble shoot. I have known guys to give up on projects like this only to find out they just needed to switch 2 wires on the security system and she fired right up.
This is a link to a site that tell you what all you need to change when crossing years. Note, the small matrix at the bottom of the page, they just use letters but one letter can be a lot of work. Especially when it indicates changing the in dash wiring harness.
3.4/3.8 V6 to LT1
jwolfe2kx
Jan 30, 2015 06:43 AM
djs383
Jan 12, 2011 01:20 PM
citypester
Nov 1, 2010 12:47 PM
buddywackos
Apr 25, 2009 03:43 PM
BlitzKrieg
82-92 V8 Tech
Mar 20, 2007 11:28 PM
