2000 v6 good clutch to buy
Old Nov 5, 2010 | 05:20 PM
chevypro101's Avatar
Default 2000 v6 good clutch to buy
clutch starting to slip what clutch kit do you recommed... it's a t5 factory for now because I just got... 70,000 miles on car/engine... going to do bolt on and gears/posi... later single turbo kit... but I still want a good clutch pedal without being hard to push only in case wifey drives....and last has any one tried one off ebay???
Old Nov 6, 2010 | 10:16 AM
All the lower end ebay clutchs for our V6's are junk. Even the ones that are OEM. I did a lot of research and found a lot of guys replacing the cheap clutchs in 3 to 6 months.
This was the best price I found on a clutch that everyone seemed to like. It has a stock feel.
http://www.jegs.com/i/Centerforce/183/DF504076/10002/-1
Don't forget you will need a fly wheel and Release bearing/slave cylinder. Its also a good time to replace the clutch master cylinder.
Descrasnezul
Sep 4, 2013 08:16 PM
Everett#2390
Oct 31, 2012 06:24 PM
coopdc78
Jan 16, 2011 11:23 AM
Z28Reggie
Nov 18, 2008 12:32 PM
BeachBrad
Aug 10, 2007 11:54 AM
