Wheel Hop
OK just purchased this vehicle. 99 Camaro v6. prior owner put cheap shocks on it, Monroe Sensa Craps or whatever they are called. ball joints were bad had a bad clunking sound when going over bumps, I replaced them and fixed the clunking noise, But when going over bumps at speeds about 45 when i hit a pretty good size bump i get wheel hop and car kinda bounces out of control. the shocks are brand new looking, i was reading on other forums to get bilsteins or konis, its just a every day driver, could someone help me with this issue, would those monroe shocks cause that wheel hop ? and is it worth it to put bilsteins on it ? and what type of bilsteins for a every day driver.
The panhard bar controls a lot of the wheel hop in corners and bumps. Check its bushings or see if its split/cracked.
Originally Posted by Failed Devices
(Post 656944)
If you've got a lot of miles on it, its likely many of the suspension components could be worn. Anything can cause wheel hop from bad control arm bushings to bad shocks. Once you get over 100k miles, it all should be replaced since the parts weren't designed to last forever.
Any set of Bilsteins will be better than those sensacraps.
Fender
Originally Posted by FBodyjunkie
(Post 657086)
Yep get that panhard bushing replaced and your issue should go away.
As for the fender issue, thats extremely common when shops don't know the correct lift points on the car. You can fix it yourself quite easily. Jack the car up and look underneath. A flange with 2 bolts hangs down vertically and keeps the fender tight, however, when a shop incorrectly lifts the car, this flange gets bent horizontal and causes the fender to bow out. You can probably find picture of the flange by searching google or ls1tech but it is easy to spot when you know what you are looking for |
Check out his fender thread: https://camaroforums.com/forum/93-02...t-place-72962/
There you go! That's the pic you need lol
(Post 657175)
