rear end
First the 4th gen rear will fit. Brake lines lining up is a good question and in most cases no. How the bad news, the 4th gen rear is 4" wider overall, so your wheels & tires will stick out 2" more per side then stock. Also depending on your wheel offsets you may have a problem there also[sm=gears.gif].
libertyforall1776
Nov 10, 2007 03:04 PM
