Lowering Springs
Old Aug 27, 2012 | 01:44 AM
flowride's Avatar
Default Lowering Springs
I looked on a search and I'm sure it's there, but I'm afraid I'll have to ask. I tried lowering my car with a 1.5" drop and the damn thing bottomed out with every tiny bump in the road. I loved the look and handling, however. So here are my questions:
What lowering springs would you recommend, if any?
Is there any way to add lowering springs and NOT have the car bottom out (ie, spacers/bump stops)? If so, what size would be best?
OR...would you just look for stock replacement springs?
Old Aug 27, 2012 | 07:56 AM
have a look at strano's springs, they lower 1.2 inches, and dont lose there spring hight like the other aftermarket springs.
Old Aug 27, 2012 | 01:12 PM
greenarrow's Avatar
September 2009 ROTM
How did you lower your car? Did you cut the stock springs?
I have BMR lowering springs and they have worked out great and improve the handling.
Old Aug 28, 2012 | 09:21 AM
Greg08's Avatar
BMR with what struts?
Old Aug 28, 2012 | 11:47 AM
greenarrow's Avatar
September 2009 ROTM
I'm using KYB adjustable all around.
Old Aug 28, 2012 | 04:46 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
I also use kyb agx on all 4 corners.
Old Aug 28, 2012 | 06:25 PM
flowride's Avatar
I used lowering springs but can't remember the brand. I just know the car bottomed out everywhere I went. KYB shocks.
I'll look into those springs, craby. They are next, along with a strut tower brace.
Old Oct 18, 2012 | 11:16 AM
sreed1236's Avatar
i lowered my 96 rs 2 inches all the way around and i had the same problem bottomed out every little bump so i ended up putting bilistein hevy duty shocks on it also just in case i put bump stops on it also made by energy suspension and i dont have any problem with bottoming out anymore
Old Oct 20, 2012 | 04:41 AM
flowride's Avatar
Thanks for the tip. I actually just did my brakes all the way around (slotted & cross drilled rotors), so I will be looking into this shortly. I gotta do everything a little bit at a time. Keeps the Mrs. happy that way.
Old Oct 21, 2012 | 10:44 AM
sreed1236's Avatar
yea i heard that haha lucky me the mrs. likes the camaro a little more than i do i think
