Project "Wamaro" Build Thread
Old Sep 14, 2011 | 08:21 PM
marten's Avatar
your lucky you have access to all the machinery
Old Sep 15, 2011 | 07:53 AM
iLL95's Avatar
I Like to Party
Super Member
Lookin good so far.
Old Sep 15, 2011 | 06:03 PM
NorthernCrew454's Avatar
Got the block in the pressure washer, 180 degree water for 15 minutes.
Next it goes in the magnaflux machine to look for cracks. There were none!
Then the block is put back into the washer to clean the magnaflux solution off and comes out nice and clean!
Old Sep 15, 2011 | 06:05 PM
Next Wednesday I plan to cut the splayed caps in and maybe line bore
Old Sep 28, 2011 | 07:20 PM
Got a bit done tonight.
Cut the caps to the correct clearance in the block, milodon says .003 Max
The overall width of the caps did not fit, so i had to cut them to have a .005 interference fit.
Then the caps all fit!
I only had enough time to drill one of the splayed bolt holes in the block. I will finish them tomorrow and thread them also.
Old Sep 29, 2011 | 07:07 PM
After all the holes where drilled, none into the water jacket, the holes are tapped
Then finished off with a flat bottom tap
everything done!
Next line bore and hone!
Old Sep 29, 2011 | 08:11 PM
is that a special bit holder so it stays in line when drilling?
Old Sep 29, 2011 | 09:00 PM
yes its a guide for drilling
Old Oct 5, 2011 | 08:34 PM
Finished bottom tapping and cleaned in the jet washer
Main studs installed, i have the longer studs for the windage tray, but since i had the short ones form the ARP kit i used them so i can mount the block to the boring machine without problems.
Studs all torqued down for cylinder boring on Wednesday and then line boring/honing next week
Old Oct 12, 2011 | 07:44 PM
  #20
Completed all the boring tonight, bore size of 4.025, leaving .005 for honing for a total bore of 4.030. The machine is a Rottler F5.
