No crank no start
Old Dec 28, 2025 | 05:59 PM
Bluecanu1972's Avatar
Default No crank no start
I recently brought home a 1994 Z28 Camaro that had been sitting in Grants Pass, Oregon for anywhere between five and 10 years. I got it off the trailer, power washed the outside, put a battery in it, and tried to crank it. It has no crank. I have taken the starter off, and bench tested it. The starter operates fine on the bench, but when I put it on the car, it does nothing. It is not even trying to push the Bendix out. The car has a brand new battery, brand new positive cable down to the starter, brand new negative cable down to the motor mounts. I do have 12 V at the signal wire when the key is in the start position. I also noticed that when the key comes on, there is no security light, or check engine light illuminated. Any help would be greatly appreciated.
Old Dec 29, 2025 | 07:33 AM
well that's a head scratcher. have you tried to get starter to work by jumping the exciter post to the hot/big post to make sure it works while installed
Old Dec 29, 2025 | 08:38 AM
I have. It really doesn’t make any sense to me. I’m going to work on grounds this weekend
JohnnyZee78
May 11, 2021 05:48 AM
Ghosttowncs
Sep 19, 2017 04:28 PM
JustGreen
Feb 27, 2013 04:40 PM
mccoyj91
Nov 28, 2010 07:55 PM
KeithZ28ss
Feb 14, 2009 11:26 AM
