My 96 RS build.
Saw your dash thread, turned out looking great. The only thing I would change is not using cardboard on the back side patch. When I half-moon cracked the dash on my old 96, I patched the back side using epoxy and fiberglass cloth. The epoxy will soak through the glass, bonding it all as one. I didn't wrap mine, but after I fixed the crack, only I knew it was there. I like your vinyl wrap look better, takes away from the plastic look, which these cars have plenty of.
Well finally got some bolts to fit the back side of the compressor, man that vibration was driving me nuts.
also found out i had some parking/turn signals lights out while i was down there, so i went ahead and replaced them all, on the front.
also did the blinker mod since i was in there and its free if you have a few wire connectors.
heres the mod for those that dont know what it is. Did the blinker mod
some really old pics i found, man has she changed a lot.
#20
That's an optical delusion. The one pipe with the weld is an up and over the rearend for the passenger side. But look closely, the pipe that's to the left and curves below is still open and unfinished. The drivers side tail pipe isn't connected to it yet.
