Gen1 sbc into 95 z28
Old Oct 17, 2013 | 08:08 AM
J3tt95's Avatar
Default Gen1 sbc into 95 z28
I have a 95 z28 with a t56 with no motor and the car is real clean but I don't want a lt1 I have sbc already and I'm wider it what has to be changed motor mounts fly wheel etc. if u guys have any more helpful info tht be awsome and how I use the t56 with the old school motor like what wires and sensors I have to leave in it for it to work thanks
Old Oct 17, 2013 | 09:11 AM
Old Oct 17, 2013 | 02:41 PM
You would Really have to hate the near 300HP 28MPG Lt1 for it to be worth it. The T56 conversion alone is going to require a speical Flywheel and Clutch assemble. Last time I looked the setup cost close to $800. Now add in the fact you going to have to rewire the whole car and make most of the brackets. You could easily build a 400 HP Lt1 for what all this crap is going to cost you to convert to your SBC.
Old Oct 17, 2013 | 09:54 PM
YAV8's Avatar
The flywheel assembley is the same as any one piece seal motors. The crank in the Lt1 and the vortec motors are the same with 526 being the last three numbers. I would use a vortec truck motor with the vortec heads and a Comp. roller cam of your choice just so its under 500 lift with a little work to the springs and your easly into the 400+ range. The only thing that will not fit into a vortec 880 block is the heads and the lt1 block. Crank rods pistons (love those lt1 flat top mahla pistons) cam lifter dog bones and spiders. Put a carb and a HEI with a vortec intake and a electric fuel pump and your set. OR just stroke the motor to 377 with a standard bore kit save the money used to bore the motor and get a new roller cam.
camarojunkie97
Mar 3, 2013 09:41 PM
dankritzersr
Mar 3, 2013 07:44 PM
mario82z28
Feb 23, 2009 10:19 AM
jml317
82-92 V8 Tech
Mar 6, 2008 12:49 AM
