Chaotic's Progress Thread
#883
Check engine is on because of my EGR delete. The check gauges light is on because my oil pressure sensor is not hooked up. I'm more worried about my speedometer not moving at all lmao.
#886
Engine or trans problem? The thing about driving around with your warning lights already on, is you don't know when something new crops up. Chances are that whatever was causing the speedo not to work, may have tripped an error code. Or, did you just scan it again to check why the speedo was dead?
#888
Yeah, that would be the VSS (vehicle speed sensor) I suggested earlier. Sounds like the least of your problems now. Sucks about the locked up trans, how many miles did that one have on it?
#890
Well guys I'm thinking I need a new clutch.... Again.... For the second time in 4 months.... When I pump the clutch, the slave cylinder moves just fine. So it's not the hydraulics. Also I can change gears while the car is shut down. But not while it's started. I can't start it in gear because the clutch won't disengage. I have to start it in neutral. And while started it won't go in any gear. Great. And id be willing to bet that my clutch doesn't have a warranty..... FML...
