93 Camaro lt1 Build, Craby's
#192
mounted the box on the driver side and ran wires behind the booster, using online mounts for the coils #12573190. tied into the solid pink wire at the coil harness. took wire out and did away with the tach module cut and connected ltcc pink wires to the pink wire and ltcc white to white wires and tucked them back in the loom. get new plug wires on fri or mon. msd wires are a little on the long side. lol. got some new ngk laser iridiums im going to try. see if i can get a little better life outa them. supposed to be harder to foul them. they come today. oh joy i get to change plugs
#195
how many grounds do you have on the car?
#196
have two extras running from battery to motor and battery to frame. think maybe run one to the dash. im not so sure its the ground. ill run a ground from battery and recheck volts.
#197
found the problem a while ago, ignition switch was toast. both stayed the same at 13.4 im gona retest volts and see what its doin now. ran a ground to the tester from the battery and tested volts at fuse box and it stayed same. i did get some rear tires ordered and will have them next week i think. mtdr 315's
#198
the mt dr's work too good, almost no wheel spin on a full hole shot. bogs a tad. next step another center section with 411 gears. then i may switch the 370s to 342 for highway. or go with a shot of nitrous.
