Z28 gages in a v6
Old Oct 13, 2008 | 10:51 PM
01camaro.dude09's Avatar
Default Z28 gages in a v6
my friend replaced his gage clusters in his Z28 and said i could have his old one butis there any way i cangetit to work for a v6. its the 155 mph
Old Oct 14, 2008 | 10:51 AM
02StanGT's Avatar
Default RE: Z28 gages in a v6
Is it from the same year or close? I have Z gauges in my car (I have pics on my FQuick link in sig). Tach reads 75% of what it should (can be corrected if desired), and oil pressure still points the same way it would on the 6. For example the 6 oil pressure gauge reads 0-60-120 and the Z reads 0-40-80. On the 6 gauge it would point to 60, on the Z gauge it points to 40... Other than that, everything else reads fine.
Old Oct 14, 2008 | 07:04 PM
yeah 2000. mines 2001 but what about the speedometer
Old Oct 14, 2008 | 09:55 PM
02StanGT's Avatar
ORIGINAL: 02StanGT
That includes the speedometer.
Old Oct 14, 2008 | 10:29 PM
oh lol my bad. thanks for the help man
Old Oct 15, 2008 | 11:10 AM
02StanGT's Avatar
Just a heads up... If it has an ASR and/or SKIP SHIFT light/s, you will need to cover those (I used electrical tape). From what I understand, they will be lit up all the time.
Old Oct 30, 2008 | 04:02 PM
Sniper's Avatar
02StanGT, your gauges look sweet, I have a Z28 but only goes to 115, If I was to change the gauges to 155, I would also have to mod the comp if I actually wanted to go that fast right? Also, would it be possible to swap with a newer model, say 97 since those are different. Mine is a 94
Old Oct 30, 2008 | 08:22 PM
02StanGT's Avatar
You would have to get a tune to have the speed limiter removed. Not sure if you would be able to use the 97+ gauges or not. I would think for sure you would be able to use the 155 ones from similar years as yours (93-96).
Old Jan 5, 2009 | 02:43 AM
95mero's Avatar
WERE CAN I GET A DIFFRENT GAGE CLUSTER FOR MY 95?
Old Jan 5, 2009 | 01:01 PM
Fortee's Avatar
ORIGINAL: 95mero
Try ebay for a cheap cluster
LolVtech
Mar 11, 2014 11:59 AM
CCarRocks
82-92 V8 Tech
Nov 4, 2007 08:05 PM
