Power window motor swap...
Old Jan 11, 2013 | 07:28 AM
Randy Bilyea's Avatar
Default Power window motor swap...
So, I swapped out my passenger side power window motor last night. It was failing in the usual manner, and I was getting tired of "helping" it up.
I followed the instructions from Shbox's site, and boy, am I ever glad I did.
Had I not looked at the correct rivets to remove, I would have taken out the regulator ones for sure, just from looking at it from the back.
Total time, 1 beer. Err...just under an hour.
Picked up the motor of fleabay for under $50, shipping in.
If anyone is planning on doing this swap, I highly recommend this link!
Old Jan 11, 2013 | 11:08 AM
jkeaton's Avatar
The PO replaced my motors before I bought it, but I was in there the other day trying to get the window adjusted right and noticed great big screws and washers where the outer rivits are so apparently he drilled out the wrong rivits...lol
Old Jan 11, 2013 | 05:57 PM
Yea, the regulator rivets are quite large. The 3 that hold on the motor are tiny. Easy mistake to make. I think that is about nine hours Shbox has saved me so far. Only had the car since August. Many more to come I am sure.
Old Jan 11, 2013 | 06:14 PM
that info and more in the how to and faq sticky at the top of the fourth gen general section. number 14, 14.5 and 15 on the list in the second post https://camaroforums.com/forum/93-02...rt-here-38462/
Old Jan 11, 2013 | 07:53 PM
Doh! Too bad you didn't say something earlier: AutoTrix :: Passenger Window Fix Kit
Old Jan 12, 2013 | 12:07 AM
Yea, this was definitely a motor issue, not a wiring issue. With the new motor it fairly 'leaps' up now....about twice as fast as the drivers side now.
Old Jan 12, 2013 | 08:42 AM
It's always a poor wiring issue, which in turn can make it a motor issue.
But often times the symptom is reversible without having to replace the motor.
Old Jan 12, 2013 | 08:46 AM
Well, the OEM motor lasted 18 years. If I get half that out of the aftermarket motor, I will be super happy.
Old Jan 15, 2013 | 08:33 AM
greenarrow's Avatar
September 2009 ROTM
Use autozone motors next time, they have a lifetime warranty, so you buy one and when it goes out you take it out and go get another one from them. I've had pretty good luck with there motors lasting about 2 years on my Z with DD duties.
cornmuffin
Jul 24, 2014 10:22 AM
Triangle12
Apr 21, 2012 08:11 PM
Jerry95lt1
Nov 29, 2010 07:59 PM
camaroglen
Aug 28, 2010 08:58 AM
jml2002
Jul 26, 2007 11:22 PM
