Dash Pad Cover/Cap Question
Does anyone know if the dash pad covers that you can buy that are designed to mount over the top of the stock dash pads can be installed without having the stock dash in place?
Mine is so shattered that it cant really be put back in place. (Stepped on it when I had it out trying to fix it haha) and the covers are a lot cheaper than oem replacement Thanks! |
If I'm not mistaken, those things are glued onto the original dash piece. I don't think you can actually use it as a replacement.
Why don't you try junkyard replacements instead? I don't think the sun would do damage to a dash that isn't damaged in such a short amount of time. |
i have seen members glue the oem pad back together and put the cap on it. i think its a fitting issue without the pad, the cap will not stay in place without pad.
Where can you find these pads?
you may want to check out 6LE Designs LLC, he has dash pads that he makes that are stronger then stock. Those things are impossible to find in one piece anymore
wow 170 bucks is a great deal.
I think its a little pricey to be honest, when you factor in shipping, its 220 bucks to your doorstep, if you wait until around the holidays (after you've spent all your money already) he normally hands out 20% off deals which essentially negates the shipping, but yeah, I need to order one for my car, I just can't bite the bullet
thats a cap that goes over the dash pad, for 10 more bucks and shipping you can get the dash pad from 6le.
just fyi, 6LE just sent out a message on facebook saying if you enter code "CMJ" in at checkout, you get 15% off your order
