Damn door sagging!
Damn door sagging!
Ok so i have a 94 camaro. These doors are very long and heavy. So my driver side door when i open it sags... therefore doesnt like to close. It's pissing me off and making me sad. What is the best way to fix this? Thanks
RE: Damn door sagging!
just replace the hinges and there u go they are expensive like i had to do it on a t-bird last year and its juss a pain by yourself. so get a buddy to help
but it cost like 20 bucks er sumthn like that.
Replacing the hinges is the last thing you want to consider, mainy because they're welded to the doors.
Your bushings and pins are worn. Replace them with something like this kit: Door Hinge Bushings & Pins
The old ones won't fall right out though. You'll have to do a little grinding, but it'll be much easier than replacing the complete hinges.
