can i swap speakers around?
Old Jan 4, 2014 | 10:07 AM
themadness's Avatar
Default can i swap speakers around?
my 96 has the 5 speaker bose set up. the passenger side door panel speaker is fried and cuts out from time to time. can i take the speaker in the hatch area and move it to the door?
Old Jan 4, 2014 | 11:35 AM
MKCoconuts's Avatar
Not the one from the hatch, I believe it's oval, not round, but either from rear seat area should fit.
Old Jan 4, 2014 | 04:52 PM
GaryDoug's Avatar
First of all the rear seat speakers are subwoofers and would not sound right up front. Second, the rear speaker is an speaker/amplifier combo for the subwoofers also. It might be difficult to extract just the speaker and leave the subwoofer amps intact.
Old Jan 4, 2014 | 10:39 PM
MKCoconuts's Avatar
The rear speakers by the rear seats are not subs. They are the same as the front door speakers. The rear speaker(s) in the hatch, however, is a sub. All the speakers in a stock F-body are a speaker/amp combo.
Old Jan 7, 2014 | 11:30 AM
DrDuran's Avatar
If you have a monsoon or Bose stereo they're speaker/amp combos. If you have a base cassette deck they're just speakers.
Old Jan 7, 2014 | 01:07 PM
themadness's Avatar
the grilles have "bose" labels but the speakers themselves have no identifying marks. i put a factory cassette deck in myself and repaired a hack job to the harness done by the previous owner. if i replace the front ones with off the shelf aftermarkets, is there a certain kind i should get?
Old Jan 7, 2014 | 06:51 PM
did you use a oem bose stereo, if so you will need speakers that will work with the amps in the bose system. heres what i kept finding.
The factory system uses amplified speakers that only work with the Bose® radio. If you replace one of the factory speakers, you'll have to replace the entire system
Old Jan 7, 2014 | 08:04 PM
themadness's Avatar
no i just put in a factory unit from the junkyard
Old Feb 12, 2014 | 11:44 PM
Brian Youngblood's Avatar
i got to check my speakers out tomrrow
94ChevyCamaroV6
May 10, 2012 10:59 PM
usnfenix
LS Series Tech
Nov 23, 2009 10:42 PM
Prime1979
Aug 27, 2009 01:16 PM
spectre460
Feb 3, 2008 01:04 PM
hateandanger
Sep 10, 2006 07:36 PM
