4th gen Replace stock dash lights with white LED's?
Old 03-21-2009, 03:16 PM
mstephens20's Avatar
Originally Posted by 02StanGT
Are you talking about the bright light, turn signal, and brake lights on your gauges? If so, only the bright light and turn signals can be replaced. The brake light one is a soldered in there and is an LED. If you decide to do the bright light and turn signal lights, I suggest you get a blue led, and a couple green ones. While they would be this color even if the led's were white, it just makes the color much more vivid.
im gonna try and replace any tht i can on the cluster gauge so i should get like 9 blue led and a couple green led 194 bulbs right...
i was talking about the extereir light bulbs on the site superbrightled.com they have bulbs to replace those and i was wondering if theyd be bright then my existing ones...
  #72
Old 04-01-2009, 02:56 AM
Blasko's Avatar
Default Glowing Rockstar
I Put The Rockstar under one of my blacklights.
It Does glow, but not as intensely as you would think
But it sure does glow. Probably not good for the health.
Pictures Don't Do Justice
But You Get The Idea
  #73
Old 04-16-2009, 10:02 PM
DMateo's Avatar
Alright so I need qty 5 WLED-x5 LED Wide Angle LED bulbs for the gauges - which bulbs specifically for the green turn signal arrows?
Also is there any way to change the lights to LEDs on the stock Monsoon head unit (without breaking it lol)?
  #74
Old 04-16-2009, 10:04 PM
02StanGT's Avatar
Turn signals are 194 size. You can replace the HU bulbs, but you need to know how to solder.
  #75
Old 04-16-2009, 11:01 PM
DMateo's Avatar
Ok thanks, yeah can't wait to see how the gauges look, but they won't match the lights on the HU/HVAC, until I get around to doing them all I guess
  #76
Old 04-17-2009, 08:03 PM
DMateo's Avatar
Wait so to clarify, do some of the 5 WLED-x5 clusters that Zoilus recommended light up the turn signals / etc? Or are there separate bulbs... I'm a little confused as to how many bulbs there are under there.
  #77
Old 04-17-2009, 08:14 PM
02StanGT's Avatar
There are a total of 9 bulbs. 5 for illumination, 2 for the signals, 1 for brights, and 1 for the odometer. On mine, I got green bulbs for the signals, and blue for the bright. Makes it much more vivid.
  #78
Old 04-17-2009, 08:21 PM
DMateo's Avatar
Alright thanks stan, yeah that's what I want to do.
  #79
Old 05-06-2009, 08:47 PM
DMateo's Avatar
Anyone know how, or know of a guide for replacing the shifter lights?
  #80
Old 05-06-2009, 08:53 PM
BiNuX's Avatar
what in the hell hahaha
Quick Reply: 4th gen Replace stock dash lights with white LED's?
