1999 Camaro Bright Switch not engaging
Old Jul 26, 2013 | 06:20 PM
PatrickM's Avatar
Default 1999 Camaro Bright Switch not engaging
My Brights lever has never engaged since new. I'm assuming that it is like most other cars and clicks when it is engaged. But all it does is pull towards the driver and go back into its normal position without any results. I replaced the whole lever today because it was all grimy, and I was thinking that it might help the problem, but it did not. So any answers would be greatly appreciated.
Old Jul 26, 2013 | 07:05 PM
need to adjust the switch or replace it. the dimmer switch is on the lower columm down by your feet. need to drop the steering columm a little to get to em on the 93-97 i assume it is close to the same thing on yours. look in the manuals section and check.
Old Jul 26, 2013 | 08:32 PM
PatrickM's Avatar
Alright so I went down there and found the rod that engages the switch. I was able to move the rod and press the button, but when I tried to move the Bright switch ( Or blinker switch) it would not connect with the rod. Any ideas?
Old Jul 27, 2013 | 12:08 AM
probly unhooked from the blinker lever. try and look at the 99 file here. My Files
Old Jul 27, 2013 | 12:18 AM
so the bar that runs down the columm is not moving right
Old Jul 27, 2013 | 03:02 PM
PatrickM's Avatar
Correct the bar is not moving unless I manually move it into the dimmer switch.
Old Jul 27, 2013 | 10:34 PM
can you move it up or down to see if its contacting the blinker lever. move the lever as you move the bar and you should be able to feel the movement in the bar when its touching the lever. move it in that same direction (dont get carried away) and see if you can get it in the hole. might get lucky. i did when changing my switch.
Old Jul 27, 2013 | 11:01 PM
PatrickM's Avatar
I had no luck in trying to get it fixed that way, so I took apart the steering assembly, and found that for some reason that the lever wasn't hitting the little black piece to move the rod. I'm gonna take a look at that in the morning as for now I am fixing a wire on the ignition cylinder that someone cut itself on a piece of plastic. Frustrating, but very interesting and fun to learn about this stuff.
Old Jul 27, 2013 | 11:45 PM
that file is so much faster when its on the computer. at least it is for me. i did part of one and its much easier to work with. took forever to transfer on this old mac.
Old Jul 28, 2013 | 01:18 PM
PatrickM's Avatar
Alright so the whole ignition didnt work out as I was putting it back in the wires came out of the cylinder, so i went and bought a new one from autozone. But another question is do i need to get a special key made with the VATs on it? The keys that came with the cylinder work to turn it, but I dont know much about this?
