Would you say my Camaro is rare?
Hello, checked my VIN number on http://www.compnine.com/vid.php and got this.
Rarity...
Out of 49,339 1998 CAMARO 2 DR vehicles there are 27 (0.055%) matching your exact options list. There are 43 (0.087%) with at least as many options.
I would like to know if my car is conciderd to be rare or not. 2 brothers I know that know their chevys well say diferent, one of them would say that it is quite rare and the other one thinks that it´s not.
So I´m Asking you guys wath you would say![Smile](https://camaroforums.com/forum/images/smilies/smile.gif)
And could someone tell me wath these codes are as it says that they are unknown?
B63
R7K
Here is the whole PRO code list for my car:
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) KILO & MILES POSITIVE BIAS SPEEDO(UC2)
UK2 LEVER,DIRECTIONAL SIGNAL(EXPORT) T/SIG LVR(UK2)(EXPORT)
UL2 RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2)
UW3 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASSETTE, DATA SYSTEM, CLOCK, ETR RADIO AM/FM(UW3)
UZ7 SPEAKER SYSTEM 8, QUAD FRT DR MTD, DUAL SAIL PNL, DUAL RR HATCH, AMPLIFIER 8 SPKR SYS(UZ7)
U75 ANTENNA,POWER(CHROME) PWR ANT(U75)
VA5 LANGUAGE LABEL(ENGLISH) ENGLISH LANGUAGE LABEL(VA5)
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND JAPAN(VC5)
VD1 PROVISION OPTIONS,EUROPE(EXPORT) EUROPEAN PROVISIONS(VD1)
VE2 PROTECTOR SOURCE APPLIED PROTECTOR(VE2)
VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT CLEAR UNDERHOOD CORROSION PREVENTIVE(VG1)
VG4 PROTECTOR UNDERVEHICLE COMPOUND, CORROSION PREVENTIVE, WATER BASED, BLACK BLACK UNDERHOOD CORROSION PREVENTIVE(VG4)
VG9 PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9)
VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VEH ID PLT(VH5)
VJ4 LABEL, EXPORT CHILD SEAT LOCATION LABEL CHILD SEAT LOCATION(VJ4)(EXPORT)
VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4)
VL5 LICENSE PLATE,REAR MOUNTING PACKAGE(EXPORT) RR LIC PLT MTG PKG(VL5)
VP6 NOISE LEVEL CONTROL NOISE LVL CONT(VP6)
VR7 HOOK TOW, SECOND, RR RR SECOND TOW(VR7)
V76 HOOK,FRONT TOW FRT TOW HOOK(V76)
HOOK,FRONT TOW(EXPORT) FRT TOW HOOK(V76)
V78 VEHICLE STATEMENT(DELETE)(EXPORT) V78)
WX7 WIRING PROVISIONS WRG PROVISIONS(WX7)
Y87 PERFORMANCE ENHANCEMENT 3800 GT 3800 GT(Y87)
1SA PACKAGE-OPTION 01 (1SA)
14I INTERIOR TRIM LT GRAY (14I)
144 TRIM COMBINATION LEATHER, LT GRAY (144)
6PU COMPONENT FRT LH COMPTR SEL SUSP(6PU) SUSP(6PU)
7PU COMPONENT FRT RH COMPTR SEL SUSP(7PU) SUSP(7PU)
8TH COMPONENT RR LH COMPUTER SEL SUSP (8TH) SUSP(8TH)
81U EXTERIOR COLOR,PRIMARY (81U)
EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)
9TH COMPONENT RR RH COMPUTER SEL SUSP (9TH) SUSP(9TH)
ABN SENSOR OXYGEN NON-HEATED NON-HEATED O2 SEN(ABN)
AG1 ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER MULTI-DIRECTIONAL PWR D/SEAT ADJR(AG1)
AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE PASS SI INFL RST SYS(AK5)
RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) MAN RST SYS(AX4)
A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) EUROPEAN WDO GLAZING(A26)(EXPORT)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
BAG PARTS PKG EXPORT PARTS PKG(BAG)
B63 Unk.
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
CT1 COUNTRY,BELGIUM(EXPORT) BELGIUM(CT1)
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
DD9 MIRROR,O/S,RH & LH REM CTL ELEC,BREAKAWAY(PAINTED)(EXPORT) O/S ELEC R/CON PAINTED MIR(DD9)(EXPORT)
MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL ELECTRIC,BREAKAWAY(PAINTED) O/S ELEC R/CON PAINTED MIR(DD9)
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
D21 SUNSHADE WINDSHIELD(EXPORT) W/S SUNSHADE(D21)
EXP EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
F41 SUSPENSION,FIRM RIDE HANDLING,FRONT AND REAR FIRM RIDE & HANDLING SUSP(F41)
GU6 AXLE,REAR,3.42 RATIO 3.42R(GU6)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
IL4 TRIM INTERIOR DESIGN (L4) (IL4)
JAF BRAKE PROVISIONS EUROPE SPECIAL BRK(JAF)(EXPORT)
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65)
K29 MODULE,POWERTRAIN CONTROL POWERTRAIN CONT MODULE(K29)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K68 GENERATOR,105 AMPERE 105 AMP(K68)
L36 ENGINE GAS, 6 CYL, 3.8K, MFI, V6, HO (ERV6 SERIES) 3.8K(L36)
MAE MARKETING AREA EUROPE(EXPORT) EUROPE(MAE)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NP7 STEERING COLUMN(EXPORT) STRG COL(NP7)(EXPORT)
N98 WHEEL,CHROME,VAR 2 WHEEL,CHROME(N98)
QII TIRE ALL P215/60R16 BW R/PE ST TL AL3 94H TIRE(QII)
R7K Unk.
STE PLANT CODE- ST THERESE, PQ, GM OF CANADA ST THERESE,GM OF CANADA PLANT CODE(STE)
TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC AUTO HDLP LVL SYS(TR7)
T2H ORNAMENTATION,UNIQUE REQUIREMENTS(EXPORT) ORNAMENTATION REQUIREMENTS(T2H)
T2J ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT) INTR ORNAMENTATION(T2J)(EXPORT)
T37 LAMP,FOG(DELUXE) DELUXE FOG LP(T37)
T39 LAMP,TURN SIGNAL,AUXILIARY(EXPORT) AUX T/SIG LP(T39)(EXPORT)
T62 LIGHTING DAYTIME RUNNING ----DELETE T62)
T78 HEADLAMPS CONTROL DELETE T78)
T79 LAMPS,REAR FOG(EXPORT) RR FOG LP(T79)
T84 HEADLAMPS,RH RULE OF THE ROAD,(MARKED E) RH RULE OF ROAD HDLP(T84)
T89 LAMP,TAIL AND STOP(EXPORT) TAIL & S/LP(T89)
T90 LAMP,SIGNALING AND MARKER(EXPORT) SIG & MKR LP(T90)
/Mikael Eriksson - The crazy Swede
Rarity...
B63
R7K
B63 Unk.
R7K Unk.
![Icon Redcam](https://camaroforums.com/forum/images/smilies/icon_redcam.gif)
Rare being the only cars with your EXACT Options. Not so rare in the real world. Rare usually means a limited run special car like the Bergers or Yenko cars were. The B63 means the car was a European designated car and the other one is an option pkg #36. No other details of what pkg 36 is.
Massey
Massey
We have threads like this before? Didn't we even have some that showed as the only one of its kind. Rare options only matter if you car was rare. If it was a 98 LE1 and an odd option or a 02 SS aniversary edition with some odd options then it would be a rare car.
Even if it is a rare combination in a base model its not going to change the value or anything.
Was not thinking that it would change the walue of the car or anything, was just qurious about it ![Smile](https://camaroforums.com/forum/images/smilies/smile.gif)
Is there any webpage were I might find some information on the diferent option packages like the - 1SA PACKAGE-OPTION 01 (1SA) and the pkg 36?
/Mikael
/Mikael
NOt that I know of. Some of those options that are listed are things for the region you are in. Mid West, and northern North American cars get things like block heaters and other nice things for cold weather that the southern cars dont even list on available options. pkg 36 could be one of those options and unless a dealer near you still has a 2000 camaro option list hanging around you will prolly never know.
Massey
Massey
OH and sometimes option groups are cheaper than individual options. In 93 I was looking to buy a new S10 and there was an option group that gave you fog lights, CD player stereo, and a rear slider for like $150 extra. The fogs were $100 alone, the deck was $300 and rear slider was $90. So getting them all together in an option group saved the buyer $400.
Massey
Massey
Okey, can try to find a number to a chevrolet dealer and ask if they have one laying around or maybe can get the info in some way.
Would not be supriced if pkg. 36 is the euro spec. rear spoiler with the rear foglights and the bigger sidemirrors..
