Won't stay running
Old 03-06-2018 | 08:48 PM
Nilo76's Avatar
Default Won't stay running
If I load up the intake with starting fluid it will run for 20-30 seconds. I've got plenty of fuel pressure I don't think the injectors are working properly. I tried using a noid light and nothing, but I have power at both terminals of 1 injector plug. Need some guidance or better understanding of the optispark system
Old 03-08-2018 | 07:04 PM
Everett#2390's Avatar
Yes, you will have close to battery voltage on injector if PCM does not turn on injector, as shown by noid light.
I would suggest crank angle sensor or cam sensor is not outputting telling PCM engine is turning over.
Just for grins, jumper in a second battery as there may not be enough power generated from present battery for other circuits to work besides starter motor.
Old 03-09-2018 | 06:44 AM
what year and model/engine?
Old 03-09-2018 | 10:10 AM
Do you have spark? Security light on? Any codes?
If you play the percentages, no injector pulse and no codes would be a security issue. Of course it can be a failed PCM or mutable sensor failures or even a wiring issue.
We have had several people come here who have had the security light on for a long time but for some reason now the system won’t start. Fix the security light fix the car.
Rick Hartselle
82-92 V6 Tech
08-14-2012 06:44 PM
Redcamaro1997
06-22-2012 11:12 PM
nickshade123
03-11-2012 12:36 AM
bear9820
82-92 V8 Tech
05-05-2011 12:06 PM
orlando_trudeau@yahoo.com
06-16-2009 01:35 PM
